[SOLVED] Background of menu on subpages (not home)
Hi I need some help cutomizing the menu on one of the subpages. A page I end up when I click on a menue except the '"home" menu.
The backgound of the menu is black with white letters.
I would like to change it wo white with green letters.
I did not find something in the customizer effecting this specific menu situation.
Could you help me what and how to change?
by mlisk
Replied by mlisk on topic Background of menu on subpages (not home)
Posted 7 years 1 month ago #22921
I found a point in "analyze" where I could change the color for the background but I don't know how to change it permanent. Maybe that helps to explain what I want to achieve.
by mlisk
Replied by joomlaplates on topic Background of menu on subpages (not home)
Posted 7 years 1 month ago #22927
you can change the active menu item color in
>> Customizer > Advanced > Navbar [more] Active Color
The following user(s) said Thank You: mlisk
Posted 7 years 1 month ago #22938
A shame that I did not finf it by myself.
Works fine now.
Thanks for help.
Works fine now.
Thanks for help.
by mlisk
Replied by mlisk on topic [SOLVED] Background of menu on subpages (not home)
Posted 7 years 1 month ago #22939
by mlisk
