[SOLVED] Responsive Menu not visible on mobile phone
Responsive Menu not visible on mobile phone was created by opitzlein
Posted 7 years 4 days ago #23278
Hello!
We are using the advocat-Template.
On the mobile phone there ist no mobile menu (offcanvas) visible, only the normal menu which normaly is shown on Desktop.
Can you help us to fix this.
Our url is www.ra-sparrer.at .
Thenak you very much
Jörg
Jörg
by opitzlein
Replied by joomlaplates on topic Responsive Menu not visible on mobile phone
Posted 7 years 4 days ago #23282
konnten sie das Problem lösen?
Ich kann nämlich auf iherer Seite das mobile Menu sehen!
Replied by opitzlein on topic Responsive Menu not visible on mobile phone
Posted 7 years 3 days ago #23298
ja, am Monitor ist das Menü da, allerdings nicht am Handy.
Da ist nur die klassische Desktopansicht des Menüs sichtbar.
Wir wissen nicht woran das liegt??
by opitzlein
The following user(s) said Thank You: Darri
Replied by opitzlein on topic [SOLVED] Responsive Menu not visible on mobile phone
Posted 7 years 3 days ago #23307
by opitzlein
