[SOLVED] Template Profiles does not work
Template Profiles does not work was created by RamgeSoft
Posted 6 years 11 months ago #23377
Hey,
When using different template profiles I recognized that changes on the background picture for example are set also in the template which is not choosen. So for example
I use jp-perct default with TOP-A Background picture an main site.
for a different sub page I created jp-perfect - networking template with no background image. This was assigned only to that sub-page (in Nav-menue). But the background picture also disappeard on the main site.
I also tried to use the assign menue in template, but that seams to have no effect.
can u help me please? It is a bit urgent.
thx
Andreas
Replied by joomlaplates on topic Template Profiles does not work
Posted 6 years 11 months ago #23387
yes profiles are not supported with our themes.
Please use instead the "layouts" to assign different styles to different menu item.
Watch our video at the bottom
www.joomlaplates.com/support/documentation/warp-7-layouts
The following user(s) said Thank You: RamgeSoft
Replied by RamgeSoft on topic [SOLVED] Template Profiles does not work
Posted 6 years 11 months ago #23410
