Module does not work with your template
I bought a new countdown-module from yagendoo which does not work with that "perfect"template. I have tested it in beez and there is no issue.
In the buttom of this site web.ramgesoft.eu/index.php/lp-channelobserver
you will see a title called "Countdown MSPAngebot". Here should appear my countdown.
Can you advice me what to do to get this to run?
Thank you in advance
Regards
Andreas
Regards
Andreas
by RamgeSoft
Replied by joomlaplates on topic Module does not work with your template
Posted 5 years 6 months ago #23668
Please disable the compression.
The script is not working because of a script issua
Attachment script-2.jpg not found
Replied by RamgeSoft on topic Module does not work with your template
Posted 5 years 6 months ago #23672
compression is not active
by RamgeSoft
Posted 5 years 6 months ago #23695
Don´t get it, compression is off
by RamgeSoft
Posted 5 years 6 months ago #23701
Sorry I dont where the problem is.
Maybe the extension or something else.
And we cannot guarantee the templates will function with all 3rd party components as there is currently no certification process for such components.
BTW You can create a countdown without an extension only with css3
