[SOLVED] Tags in Module mod_roksprocket does not work
Tags in Module mod_roksprocket does not work was created by a.seidel@ubas.de
Posted 6 years 7 months ago #24522
This request refers to the site www.ferienhauskontor-greetsiel.de/
The tags on the Home page work for 3-4 klicks, and then it does not do anything. This means, I click on 3-4 options and the filtering works fine. Then it stops working and neither the "All" option nor the other tags work. After reload of the page, the tags work again for some clicks and then freeze.
Please help. Many thanks in advance,
Alex
Replied by joomlaplates on topic Tags in Module mod_roksprocket does not work
Posted 6 years 7 months ago #24532
Did you enable any way of compression?
Can I get admin access to your site? Send me the data via WhatsApp
api.whatsapp.com/send?phone=4960277180599&text=&source=&data=
The following user(s) said Thank You: a.seidel@ubas.de
Replied by a.seidel@ubas.de on topic [SOLVED] Tags in Module mod_roksprocket does not work
Posted 6 years 7 months ago #24544
Replied by joomlaplates on topic [SOLVED] Tags in Module mod_roksprocket does not work
Posted 6 years 7 months ago #24555
The problem was some wrong HTML Tags in the description
