[SOLVED] Installation problem
I purchased the jp-interior template yesterday and used the quickstart for installation. I entered the sample English data as shown.
After the installation I receive the error message that is attached.
I tried several times to do the procedure but I get the same error.
by jampicoll
it was a problem with the SQL and it is fixed
