[SOLVED] How do I make "Projects" module NOT fade ...
How do I make "Projects" module NOT fade ... was created by ofisboy
Posted 5 years 2 months ago #25595
Hi, me again …
How can I make the images in the Projects module not fade? I have removed the fade option within the module and I have also marked "no animation" in the template edit but it continues to fade.
by ofisboy
Replied by joomlaplates on topic How do I make "Projects" module NOT fade ...
Posted 5 years 2 months ago #25601
Live Url and Screenshot please
Replied by ofisboy on topic How do I make "Projects" module NOT fade ...
Posted 5 years 2 months ago #25603
I’m at work right now and can’t but all you need to do is look at the folio template preview and scroll down to “Projects”. My site has that same setup just different images.
by ofisboy
Posted 5 years 2 months ago #25607
You want to remove the "mouse over" from the images?
If you want to do like that, you have to edit our override from the roksprocket.
You will find the files at > Your template / roksprocket /
Another option is to renmae the override
www.joomlaplates.com/forum/j3-bistro/888...ides-for-roksprocket
Posted 5 years 2 months ago #25609
I renamed the folder but that only resulted in an error message (Error The parameter "roksprocket.layouts.mosaic.themes.popup.basefile" must be defined.) I also couldn't find any mouse over which didn't surprise me because the fade takes place long before a mouse ever gets near it. I wound up editing <div class="sprocket-mosaic-item" data-mosaic-content data-uk-scrollspy="{cls:'uk-animation-fade', delay:000}"> in the item.php file. I changed the delay from 900 to zero. It still fades but very fast. I also discovered that if I remove the entire animation line … ={cls:'uk-animation-fade', delay:000} … it would completely stop the fading altogether. For some reason I didn't want to eliminate that entire line so I'm satisfied with a fast fade.
Last Edit:5 years 2 months ago by ofisboy
Last edit: 5 years 2 months ago by ofisboy.
Replied by ofisboy on topic [SOLVED] How do I make "Projects" module NOT fade ...
Posted 5 years 2 months ago #25610
by ofisboy
