[SOLVED] Going edge to edge with a section
Going edge to edge with a section was created by alainchammas
Posted 4 years 8 months ago #26076
I have now been able to fix most of what I intend to do with this site, afriquesure.org
I have set the parameters in the customizer to "Side Spacing = 0%" and "Container Max Width = 100%"
The background images reach now edge to edge, which looks cool.
However, the box at the bottom, our grey "footer" (residing in bottom-b) does not reach the left or right edges, even though it's width is set to 100%. How do I fix this?
Thank you, also for all your previous support, you have been fantastic.
All the best,
Alain Chammas
Replied by alainchammas on topic Going edge to edge with a section
Posted 4 years 8 months ago #26077
Hello, answering my own question here:
Instead of setting a section colour in my module html, I have set a section background in the customizer.
All the best.
Alain Chammas
Replied by joomlaplates on topic [SOLVED] Going edge to edge with a section
Posted 4 years 8 months ago #26078
