[SOLVED] sticky menu problem:can't change placeholder color
Replied by raziel1973 on topic sticky menu problem:can't change placeholder color
Posted 5 years 5 months ago #27657
Ok I will.
I was hoping to change it in the template options. To avoid the overwrite when I'll update the template.
Thank you
Tony
The following user(s) said Thank You: raziel1973
Replied by raziel1973 on topic [SOLVED] sticky menu problem:can't change placeholder color
Posted 5 years 5 months ago #27683
