[SOLVED] Menu on small window
- davidanna23
- Thank you received: 2
Can I copy all code in custom.css or only code that I changed?
by davidanna23
I would copy only the code you changed. Otherwise its 5000 line of code and it gets a mess
- davidanna23
If I click on Customizer, Is only theme.css or even headerbar restored?
Because now I see the img background also from mobile.
If I apply the customizer, it becomes a black background and with custom.css I can’t restore it frome code in theme.css.
Can I add a white bar up of headerbar background and move down this img? Only for mobile!
by davidanna23
- davidanna23
I fixed it.
I created a theme.css before and a theme.css after the Customizer. I changed the values to px and it worked.
One last question: the logo is in too low position in ipad display (width = 1024px), compared to the gray bar. Can I turn it up a bit, just for the iPad? From 500px to 1154px. Thanks a lot
by davidanna23
