[SOLVED] Problem with Footer Position
Hi and thank you in advance about the help.
Link of my page (with this issue): www.noh-art.com/contact-us.html
I have the footer position in the middle of the page (an ugly black strip on the middle)
I know there is no enought content fo fill the empty place, but I don't know how to avoid this bad aspect of this page. And it will be worse in case the site will be visited by an user with high resolution monitor.
Please see as attached
Any suggest ?
Thank you
Any suggest ?
Thank you
by nohart
sorry the theme is dynamically., therefore the footer comes after content.
But you can add your footer content to main bottom position, then its under the content
Hi thank you for your reply. In bottom position will be worse. I think to add some content to feel the empty place.
Thank you
Tony
Thank you
Tony
by nohart
Replied by joomlaplates on topic [SOLVED] Problem with Footer Position
Posted 5 years 3 weeks ago #28831
