Problem with JD Simple contact form - List mode not showing text
- Benderamalama
Problem with JD Simple contact form - List mode not showing text was created by Benderamalama
Posted 3 years 7 months ago #30765I'm using the Wedding - Joomla Theme on Joomla 4.1.5 but I have 2 small problems.
On the site I used the JD-Simple-Contactform, with the "LIST" option my options are not showing up correctly.
Users are able to select the options but when they are selected, the text is not fully visable.
I'm also looking to remote the footer text that shows "Powered by Theme-Point" if anyone know where I can edit this?
Thanks!
Replied by joomlaplates on topic Problem with JD Simple contact form - List mode not showing text
Posted 3 years 7 months ago #307681.) List options must be customized by css ( live url pls)
2.) To change the footer you have to go to template options > www.joomlaplates.de/template-konfiguration/verschiedenes.html
- Benderamalama
Replied by Benderamalama on topic Problem with JD Simple contact form - List mode not showing text
Posted 3 years 7 months ago #30772Thanks for the reply.
I managed to edit the footer, but can't seem to find the css for the list option.
The live url is www.goffings.be
Thank you!
- Benderamalama
Posted 3 years 7 months ago #30773Thanks for the reply.
Thank you!
- Benderamalama
Posted 3 years 7 months ago #30774Thanks for the reply.
Thank you!
Posted 3 years 7 months ago #30775.form-control, #adminForm .controls > textarea, #adminForm .controls > select, #adminForm .controls > input[type="text"], #adminForm .controls > input[type="password"], #adminForm .controls > input[type="datetime"], #adminForm .controls > input[type="datetime-local"], #adminForm .controls > input[type="date"], #adminForm .controls > input[type="month"], #adminForm .controls > input[type="time"], #adminForm .controls > input[type="week"], #adminForm .controls > input[type="number"], #adminForm .controls > input[type="email"], #adminForm .controls > input[type="url"], #adminForm .controls > input[type="search"], #adminForm .controls > input[type="tel"], #adminForm .controls > input[type="color"], #adminForm .controls > .uneditable-input, #adminForm .controls .field-calendar input[type="text"], #adminForm .controls .field-media-input {
height: auto;
