Problem with tp_perfect and menu affiliation
Problem with tp_perfect and menu affiliation was created by jp_sewa
Posted 2 years 5 months ago #31673
Hello everybody,
i have a problem with assign the menu to a template. I have to templates "tp_perfect" (one in german, one in english). Now i want to set the menu in german and english. The problem is, that if i make the flags and safe the template, only a few flags are safed, the others are ignored. Maybe it is better to understand with the attachments. In this case i made the flags for the "Top Menu EN". Picture 1 shows the original (no flags set), Picture 2 the flags sets and safed, Picture 3 the information, that only 2 entries have been saved. Picture 4 shows the flags after entering the template again. Only 2 flags are set ... so ... some menu flags have not been stored. Why?
What is the problem? I have installed the latest astroid, the latest joomla 4 version and template version.
Thank you!
Nice greetings
by jp_sewa
Replied by jp_sewa on topic Problem with tp_perfect and menu affiliation
Posted 2 years 5 months ago #31674
One note: If i change the templete in joomla with "menu", the flags are stored correct to each menu item.
by jp_sewa
Replied by Administrator on topic Problem with tp_perfect and menu affiliation
Posted 2 years 5 months ago #31675
Hi!
You have to choose the template-style at your menu:
Posted 2 years 5 months ago #31677
OK ... do i need to set both languages, or is it enough, if i set the german template als "default" und also set the menu items to the default template?
Thank you ...
by jp_sewa
