[SOLVED] Onepage navigation doesn't work
[SOLVED] Onepage navigation doesn't work was created by jochen_x
Posted 3 years 4 months ago #31693
I use
J!4.2.5.
PHP 8.024
Template: tp-hotel
I created a simple onepage navigation with "url" in the menu, "smooth scroll" is activated and "#" is set.
Sometimes this works (after 5-10 seconds), most of the time it doesn't. Sometimes after switching tabs (current Chrome browser) and going back into the tab, it snaps to the anchor clicked minutes ago. After clicking the "top button" sometimes the whole page freezes for several seconds.
Chrome developer tools shows no errors :-/
The site has been updated by J!3 (jp-hotel) and the following are also installed:
JCE
SP Page Builder
baGallery
Akeeba Admin Tools & Backup
I am happy about your feedback
Last Edit:3 years 4 months ago by jochen_x
Last edit: 3 years 4 months ago by jochen_x.
Replied by joomlaplates on topic [SOLVED] Onepage navigation doesn't work
Posted 3 years 4 months ago #31694
please reduce the scroll animation time in Theme settings > Basic
Posted 3 years 4 months ago #31695
And please remove this silly "right click" protection and pagebuilder.
That maybe the problem
Replied by jochen_x on topic [SOLVED] Onepage navigation doesn't work
Posted 3 years 4 months ago #31712
OK thanks. Will there be more problems between Astroid and Pagebuilder? After the end of your old templates I still have to upgrade some pages to Astroid and wanted to use pagbuilder very often...
Posted 3 years 4 months ago #31713
pagebuilder is a framework and Astroid too.
Same like Warp7 and Yootheme pro or Rokethemes framework and they are not compatible with each other
Be careful, each framework should be installed only onced in Joomla
The following user(s) said Thank You: jochen_x
