[SOLVED] Problems with publisher in front end
[SOLVED] Problems with publisher in front end was created by Ferriero
Posted 3 years 3 months ago #31706
Hi!
I created an account with access from the front end to insert the article in the blog.
It occurs that in the Images and Links section, if you create a new folder the popup freezes and does not go ahead, even if the folder is created.
To view it, close the popup, go back and reopen the Images and Links tab.
This is not very professional.
How can I fix it?
These are the errors reported in the console:
Uncaught TypeError: Joomla.renderMessages is not a function
at Notifications.notify (media-manager.min.js?41349ab7c112a7dc4604ebd5568a311d0c57880f:1:80540)
at Notifications.success (media-manager.min.js?41349ab7c112a7dc4604ebd5568a311d0c57880f:1:80346)
at onSuccess (media-manager.min.js?41349ab7c112a7dc4604ebd5568a311d0c57880f:1:103942)
at n.onreadystatechange (core.min.js?bea7b244e267b04087cedcf531f6fe827a8e101f:1:6213)
Video Recording Screen:
Thanks
How can I fix it?
Thanks
by Ferriero
Replied by WM-Loose on topic [SOLVED] Problems with publisher in front end
Posted 3 years 3 months ago #31707
The folder is created but the window does not show it.
However, if you click Cancel or Select, the folder is created.
Please test it.
You are of course right, this is not user friendly. We will report the problem to the developers.
Please test it.
Last Edit:3 years 3 months ago
Last edit: 3 years 3 months ago by WM-Loose.
Posted 3 years 3 months ago #31708
OK, this is a problem from the jce editor.
If you set the image fields to yes in the jce options, everything works in the frontend. If you set it to no, the joomla media manager will not run properly. Test times with the tynimce and compare. It's best to open a ticket in the JCE forum.
Posted 3 years 3 months ago #31711
I open a Ticket at JCE Support:
www.joomlacontenteditor.net/support/foru...-building-new-folder
Replied by Ferriero on topic [SOLVED] Problems with publisher in front end
Posted 3 years 3 months ago #31716
Hi!
Thanks a lot!
Thanks a lot!
by Ferriero
Posted 3 years 3 months ago #31720
Astroid Issue on Github now online:
github.com/templaza/astroid-framework/issues/250
JCE is not the problem.
