[GELÖST] Website Load Speed - Template speed and Asteroid/UIKit/bootstrap JS
Hi Guys, nice templates! Novice here.
A quick question about my website greatlifecoach.co.uk built with your Travel Template.
Is there any way that the template load-time can be speeded-up? I notice there are many individual JS payloads that are made at the start of the webpage. Are all of them necessary!?
In addition, when you travel around the website, the pre-loader is often invoked from one page to the next.
For example,
-go to the home page greatlifecoach.co.uk
-Then go to the blog page ( greatlifecoach.co.uk/blog ), you will see that the page partially appears, then disappears to the pre-loader, and then the loaded page will re-appear.
Any help/insight is greatly appreciated.
Lee
Disable the pre-loader in the template options.
In addition, switch on the cache in the Joomla configuration settings to "normal caching".
Than take this Options in the Astrod Plugin:
Last Edit:2 years 2 months ago by WM-Loose
Last edit: 2 years 2 months ago by WM-Loose.
