Ulkit sliders not compatible with php8
Which update are you referring to.
We tried disabling all the Ulkit 3 plugins but we still have the same issue when upgrading to php 8.
by Jacks
Replied by joomlaplates on topic Ulkit sliders not compatible with php8
Posted 1 year 11 months ago #32860
all current Templates and Uikit modules are running well with PHP 8.0 - 8.2.
I dont seem to be able to find a way to fix the issue. I have attached a screenshot of the page as it appears when I select php8. What do you think about this?
by Jacks
Posted 1 year 11 months ago #32862
Hello, please disable all Joomla cache and clean the cache too
Cache Settings has been changed in PHP 8.
And your error message seems not to be a template problem.
Does the template need to be the current joomla 4 version and if so can I pay to get this upgraded as I'm not sure how to upgrade it?
Please see the pre update message I recieved when I went to update the template myself. I havent done it.
The message lists all the extensions. I'm not sure how to update ULKit extensions.
by Jacks
Posted 1 year 11 months ago #32893
Templates and Uikit Modules are compatible with PHP 8. x and Joomla 3 and J4.
You can install the templates and uikit modules in J3 and then update to J4.
Ofc you need an active membership to download the newest version
