[SOLVED] Centre module
Hi
We use the template tp_construction (1.3.11) with Astroid (2.6.3) and Joomla 4.
Under the menu we have the Joomla Core module 'Random image' and that should be in the middle.
I have created a new section with Row (2+8+2) and in the middle an element with the module position
prnt.sc/MOSQkZqUg-G_
But in the frontend the module is shown on the left and it seems that the two col-lg-2 elements are missing in the source code:
prnt.sc/u0PtTNduNlSY
Link to the page:
zuber-zwingen.ch/neu/
What is wrong there? I would appreciate any tips, thank you.
Roger
Link to the page:
Roger
by mhp
if there is no Joomla Module assigned to the row the module will not be shown.
Put a css text-center class to the element or section to center the image
www.joomlaplates.de/joomla-tips-und-tric...nen-im-template.html
Hi
Thank you very much, it worked!
Thanks
Roger
Thanks
Roger
by mhp
