[SOLVED] Standard and Custom Modules not appearing in positions
[SOLVED] Standard and Custom Modules not appearing in positions was created by croftie
Posted 2 years 7 months ago #33370
I have just upgraded to Joomla 4.3 and also upgraded to TP-Biz Latest. None of my modules are appearing on the selected pages after selecting a valid TP-biz position and that they are published and the correct menu assignment. I know the modules are compatible with Joomla 4 because they all work with Cassiopeia. I am clearly missing something about the astroid platform.
How do I enable positions so that I can just use modules in the same way as normal?
by croftie
- Thank you received: 123
Replied by Administrator on topic [SOLVED] Standard and Custom Modules not appearing in positions
Posted 2 years 7 months ago #33371
From 3.10.x?
And from Astroid-Framework or from Warp7-Framework?
Replied by croftie on topic [SOLVED] Standard and Custom Modules not appearing in positions
Posted 2 years 7 months ago #33372
I figured it out. Its the astroid framework an you have to specify that the layout component is a module.
by croftie
