[SOLVEd] How to display main content cell before sidebar-left on small devices?
On small devices, sidebar-left modules are displayed just after the header (Cassiopeia does the opposite).
Sometimes it's not desirable, so is it a way (CSS ?) to force the left-hand modules to be displayed under the main content? (header-main content-sidebars modules)
Thanks for your advice!
Robert
Hi Robert!
I had the same problem. My solution was a new template-style.
Ich changed the module-positions for mobile-view.
Last Edit:2 years 7 months ago by Administrator
Last edit: 2 years 7 months ago by Administrator.
The following user(s) said Thank You: RG-Consultant
Thanks for you reply!
I know how to create a new style, but I don't know how to use it only with small devices.
Thanks for your help.
Use the responsive settings:
Thanks, I found it and will try.
