[SOLVED] Footer Menu disapears on every position on Tablet
  • Milian
Replied by Milian on topic [SOLVED] Footer Menu disapears on every position on Tablet
Posted 2 years 5 months ago #33755
I have (listened to your explanation) disabled the JUX-Mega-Menu because of the disapearing on Mobile on a vertical Tablet.
Now I have add The Astroid Menu Module in the footer.
But also there within The Classic Template the menu disapears.
Hope you have a css or an overide for me to show the footer menu on moblie.
musora.nl/ja40/linken
musora.nl/ja40
Thanks a lot!
Regards,
MIlian
Last Edit:2 years 5 months ago by Milian
Last edit: 2 years 5 months ago by Milian.
Replied by joomlaplates on topic [SOLVED] Footer Menu disapears on every position on Tablet
Posted 2 years 5 months ago #33756
Hello, you have setup a section or table to hide on small and hide on medium. See picture
Please check the section, element or table row
www.joomlaplates.de/joomla-tips-und-tric...e-einstellungen.html
Attachment hide.jpg not found
  • Milian
Posted 2 years 5 months ago #33757
Thanks JP,
Indeed I found two disabled ones:
Hide on Extra-Small Devices
Hide on Small Devices.
I set them OFF.
On Tablet it is fine now.
One thing left:
On moble the menu is still gone
I found a (visual) break point on aprox. 520 PX.
Do you have a css so set this smaller?
The Astroid Menu is placed on position: Bottom-E-1.
Thanks a lot!
Regards, Milian
by Milian
Posted 2 years 5 months ago #33758
Hello, there is still a display:none in your css.> see pic attached
Maybe comes from Module class suffix or anything else. And please setup your menu module layout to >> horiziontal.
Astroid menu is only for the main menu
Attachment d-none.jpg not found
The following user(s) said Thank You: Milian
