[SOLVED] Changing Module order for Mobile is not changes in the Front-end
  • Milian
Hi, I want to change (in the Classic template) the the module order for Mobile.
First I choose (in Astroid 3.0.2) the Mobile icon.
Then I move in Astrioid-> Layout the main-module-pos (main-top-2) above the left module pos (sidebar-left-1)
But whatever I do nothing is chanching in the front-end.
maxfolmer.nl/ja40-bp/?tp=1
Order for Mobile:
main-top-2
sidebar-left-1
sidebar-right-2
What do wrong?
(Of course I save the Changes first)
Thanks a lot
and regards,
Milian
by Milian
You cant change the positions ordering for mobile devices.
But you can change the breakpoints, see pics
Last Edit:2 years 7 months ago by joomlaplates
Last edit: 2 years 7 months ago by joomlaplates.
  • Milian
Ok.
Thanks for your explanation.
I shall look into it.
Regards,
Milian
by Milian
Hi!
My solution was a secound template style.
I adapted the layout to how it should look in the mobile display.
I have released this style for mobile viewing only.
The first style for desktop view only.
  • Milian
Do you have an visual example for mobile (breaking point for a module pos. ) for me?
I am a little confused about your answer.
I am not so familiar with Astroid (Joomlaplates Templates) yet.
But I want to. I opt for an annual subscription after my 3 months subscription.
That's wy i want to invest in the Admin.
Regards, Milian
by Milian
Sorry, it was an other way.
I duplicated the modulpositions and renamed it an then i decided to view on mobile devices.
I have to check this. Long time ago.
This is the Site. You can check it with   ?tp=1  after the domain:
This message contains confidential information
