[SOLVED] module position
- WB-Autoservice
To install Astroid-Framework-Plugin 3.0.2 dismissed the failure but I missed the preset content from the quickstart. So again a new fresh start using quickstart with template "Work" hoping to avoid the error messages and to have the preset data available. Out of luck again error messages:
I don't get it in the past never had this issues with your templates.
Hope to hear from you,
Kind regards,
Hennie
. www.cambra.nlDeprecated: trim(): Passing null to parameter #1 ($string) of type string is deprecated in /var/www/clients/client12356/web146169/web/modules/mod_uk_portfolio2/mod_uk_portfolio2.php on line 20
Kind regards,
Hennie
Last Edit:2 years 4 months ago
by WB-Autoservice
Last edit: 2 years 4 months ago by joomlaplates.
- WB-Autoservice
I have deleted under modules: mod_search and mod_uk_portfolio2 from the server. No more errors but what am I missing while building my website?
kind regards,
Hennie
I have transferred the mod_UK_portfolio2 back because I need it for my portfolio. It seems it is the only way to present my foto's as I want. I hope you can fix for the error?
kind regards,
Hennie
by WB-Autoservice
Last edit: 2 years 4 months ago by WB-Autoservice. Reason: Made the change undone
- Thank you received: 123
I fixed it. It is just a deprecated-notice.
I set the error-reporting to none.
The following user(s) said Thank You: WB-Autoservice
