[SOLVED] b2b articles question
b2b articles question was created by dimrigas
Posted 2 years 1 month ago #34426
a kind of 'easy' question I guess but I'm quite confused so far..
I use the b2b template. I would like to show on my home page the latests articles at top-b position without the 'default' at top-d container area. Then, when the Read more... button is clicked, to show the full article at top-b position again.
I would appreciate any help.
Thank you!
Replied by WM-Loose on topic [SOLVED] b2b articles question
Posted 2 years 1 month ago #34429
Assign a hidden menu link to each item and it works. Google search: joomla shadow menu.
Last Edit:2 years 3 weeks ago by WM-Loose
Last edit: 2 years 3 weeks ago by WM-Loose.
