[SOLVED] Problem with tp_biz after update from Astroid Framework 3.0.9 -> 3.0.10
  • msin
Hello
After updating from 3.0.9 to 3.0.10 or newer I have the problem that the background changes to dark and I didn't find where I can change this.
Since 3.0.10  I hope the bug will be corrected.
Who has an idea?
Thank you.
Kind regards
Marcel
by msin
Hello, you can change the background in the section or in the element from the template options
docs.astroidframe.work/layout-settings/section-settings
  • msin
Super vielen herzlichen Dank.
Ich musste nur in "section settings" einfach unter "select a preset" ein Preset auswählen und speichern und der graue hintergrund ist wieder weiss.
by msin
