[SOLVED] Off-Canvas menu and mobile menu not displaying B2B
Replied by ginageick on topic Off-Canvas menu and mobile menu not displaying B2B
Posted 1 year 1 month ago #35624
I did - no change.
by ginageick
Posted 1 year 1 month ago #35625
I also turned on maximum error reporting but nothing shows
by ginageick
Replied by WM-Loose on topic Off-Canvas menu and mobile menu not displaying B2B
Posted 1 year 1 month ago #35626
Der Link zu dieser Seite funktioniert nicht.
Fehler 403.
Screenshots von Ihren OffCanvas Einstellungen bitte.
Alle Module in der Offcanvas Position mal deaktivieren und nur ein eigenes Modul mit einem Text dort einfügen und erneut testen.
Fehler 403.
Last Edit:1 year 1 month ago
Last edit: 1 year 1 month ago by WM-Loose.
Posted 1 year 1 month ago #35627
From where are you accessing the site? I may have to turn off the firewall.
And, are you using a VPN? I often get misplaced in terms of location.
by ginageick
Last edit: 1 year 1 month ago by ginageick. Reason: add question
Posted 1 year 1 month ago #35628
If need be, please send me your IP in private message.
by ginageick
Posted 1 year 1 month ago #35629
The module in the offcanvas position is a custom module with text, an image and a couple of links. Nothing fancy.
However, I did unpublish that and put a one-liner 'this is a test' in its place with the same results.
Also, I elected to not show the offcanvas position at all but that did not fix the mobile menu issue.
Settings of offcanvas in screenshot. Thank you!
by ginageick
