[SOLVED] Lazy Load Images
- alizarrouk
Hi
I am triyng to get lazy load to work. I have enabled it on the astroid framework and selected exlcude and left the box blank. This bring /media/astroid/js/lazyload.min.js but the images do not lazy load.
At the same time I selected include ( itneh astroid framework) and listed some images in the box but this did not work either.
I have tired few templates including perfect and b2b.
Any suggestions? Any more instructions on how to enable it lazy load for the entire site including JP grid and Slider?
Many thanks
Ali
Many thanks
Ali
by alizarrouk
- alizarrouk
Hi.
Thanks for this.
The intstruction is not clear. If I want to enable lazy loading for all images on the website then do I just select Except and leave the white box empty? Will it work on all image formats inculding webp formats.
Many thanks
Ali
Thanks for this.
Many thanks
Ali
by alizarrouk
If lazy loading is enabled, it applies to all images. If you want to exclude an image, you need to specify this in the field.
You can include and exlcude images, depending on what you selected
app.gitbook.com/o/5sakhWedcsRhvQ9ocEdo/s...ous/lazy-load-images
Last Edit:10 months 1 week ago
Last edit: 10 months 1 week ago by WM-Loose.
