Please post only question belong to the topic > pre sales. All support questions will be deleted.
Sobipro and templates
  • ajozsef
  • Topic Author
Sobipro and templates was created by ajozsef
Posted 13 years 3 months ago #3581
I build casino and theme parks directory with SobiPro AND ST Resorts SobiPro template.
www.sigsiu.net/sobipro.html
www.sobitemplates.com/sobipro-templates/...rts-sobipro-template
Also, I use Extended Search:
www.extly.com/xtsobipro/sobipro-extended-search-module.html
And Custom List:
www.kulendra.net/Joomla-Extensions/customlist4sobipro.html
For website design, I looking quality Joomla template.
Questions:
1. SobiPro and SobiPro ST Resorts template "compatible" with your Joomla templates ? Will this work? Or do you know about any problem (templates and Sobipro)?
2. Can you recommend quality template for "accomodation directory" (casinos and theme parks) and SobiPro?
2. Can I use extended search and Customlist extensions with templates?
I build jobsite also, with Joombah Joomla component.
www.joombah.com/
Can you recommend Joomla template for this component?
Thanks,
by ajozsef
