[SOLVED] Downloaded .zip folder and no contents inside
  • smc1st
Downloaded .zip folder and no contents inside was created by smc1st
Posted 9 years 6 months ago #9692
I have just become a member and downloaded the "Work" template. Followed the instructions on screen once downloaded which said "unzip folder first and read instructions". The problem is there is not contents in the download. Please see screen shot.
Thanks,
Steve
by smc1st
Replied by joomlaplates on topic Downloaded .zip folder and no contents inside
Posted 9 years 6 months ago #9693
please re download the file again, it must have 20MB
And please do not use a download accelerator
  • smc1st
Replied by smc1st on topic Downloaded .zip folder and no contents inside
Posted 9 years 6 months ago #9694
Hi
Thank you. I do not know what happened last time but it work fine just now. I just wanted to say i am going to be a frequent users of your templates. I like your designs and the work you do.
Thanks,
Steve
by smc1st
  • smc1st
Replied by smc1st on topic [SOLVED] Downloaded .zip folder and no contents inside
Posted 9 years 6 months ago #9695
by smc1st
