Please post only question belong to the topic > pre sales. All support questions will be deleted.
[SOLVED] Templates modifications
  • isaqua
  • Topic Author
[SOLVED] Templates modifications was created by isaqua
Posted 15 years 11 months ago #893
I\'d like to know if all your templates are modifiable ? can we change the back ground, the text color etc ...
Thanks for your response.
I\'ve used one of your templates (JP Soho) ... perfect ... thanks
Isaqua
by isaqua
  • Joomlaplates
  • Moderator
  • Moderator
Replied by Joomlaplates on topic [SOLVED] Templates modifications
Posted 15 years 11 months ago #896
Yes you can. You are authorized to make any necessary modifications to our templates to fit your needs. You can remove our footer \"Designed by JoomlaPlates.com\" and changed it to \"Designed/Powered by YourCompany\".
by Joomlaplates
Moderators: Joomlaplatesjoomlaplates
