[SOLVED] How Fix left menu like a Flexible template ?
- 3dmark
- Topic Author
- Visitor
How Fix left menu like a Flexible template ? was created by 3dmark
Posted 9 years 9 months ago #6361
How fix (make fixed in Galeria) left menu like a "Flexible" or "Setcard" template?
Thank!
Thank!
by 3dmark
Replied by joomlaplates on topic How Fix left menu like a Flexible template ?
Posted 9 years 9 months ago #6362
You can not set the sidebar "fixed" with few clicks or from backend template parameters.
But you can try following, without warranty.
Open the file > css / custom.css and add the code below:
#jp-left { position: fixed;}
Last Edit:9 years 9 months ago
Last edit: 9 years 9 months ago by joomlaplates.
- 3dmark
- Topic Author
- Visitor
Replied by 3dmark on topic How Fix left menu like a Flexible template ?
Posted 9 years 9 months ago #6363
Thanks for the quick reply!
Workedsss!
Only here the problem remains at the bottom of the menu, hiding behind the elements.
Workedsss!
by 3dmark
Last edit: 9 years 9 months ago by 3dmark.
Posted 9 years 9 months ago #6364
could not see this issue in our template. See image attached.
Live Url please.
Live Url please.
Attachment galeria.jpg not found
- 3dmark
- Topic Author
- Visitor
Posted 9 years 9 months ago #6365
in fireFox and IE normal! in google chrome behind
link in local
pls try in google chrome!
link in local
by 3dmark
Posted 9 years 9 months ago #6366
Yes youre right. Chrome need an additional "z-index" for fixed position, therefore try this code below
#jp-left {
position: fixed;
z-index: 999;
