[SOLVED] Icons errors in module and component
  • Tibere
  • Topic Author
  • Visitor
  • Visitor
Icons errors in module and component was created by Tibere
Posted 10 years 1 month ago #6815
I have icons error with 1 module and 1 component, I test with the protostar template every things work correctly (but the template is not good enough).
When I disabled bootstrap in snowflake template, all icons are back but I can't let this option disabled.
I don't know what to do exactly.
by Tibere
Replied by joomlaplates on topic Icons errors in module and component
Posted 10 years 1 month ago #6816
Live Url please to check the issue.
I think your installed extension is not compatible with the bootstrap css.
  • Tibere
  • Topic Author
  • Visitor
  • Visitor
Replied by Tibere on topic Icons errors in module and component
Posted 10 years 1 month ago #6825
www.ledevancon.fr/Joomla1
I was thinking that too so I download a template from the website of my module and component provider (solidres) that use bootstrap too ( their bootstrap file in attachments) I don't want use their template because I can't put a background image but yours can.
Last Edit:10 years 1 month ago by Tibere
Last edit: 10 years 1 month ago by Tibere. Reason: attachments missing
Posted 10 years 1 month ago #6826
Hi there, its very complex, see image below
1.) Our theme is using the "font-awesome" for the class "icon"
2.) Your extensions is using the "IcoMoon" for the class "icon"
And both icons are not working together.
Sorry there is no solution about that problem.
Attachment icons_2015-02-28.jpg not found
I have modified your "theme.css", please upload this theme.css to your folder
>> /jp-snowflake/styles/blue-clean/css/theme.css
1.) Please rename the org theme.css to theme.org
2.) Upload our modified theme.css to this path shown above
But there is one problem, the theme.css will be overwritten if you click the button "compile less" and your modified theme.css will be lost.
You can try if it work, coz there is no other solution.
Attachment theme_2015-02-28.zip not found
Last Edit:10 years 1 month ago by joomlaplates
Last edit: 10 years 1 month ago by joomlaplates.
  • Tibere
  • Topic Author
  • Visitor
  • Visitor
Posted 10 years 1 month ago #6827
The new theme.css works thank you, but a new small problem appears. On the menu only for the submenu an icon appears.
Attachment menu.jpg not found
by Tibere
Posted 10 years 1 month ago #6828
Add this code below to your theme.css at the top of the page. ( no warranty)
@font-face {
font-family: 'FontAwesome';
src: url("../../../warp/vendor/uikit/fonts/fontawesome-webfont.eot");
src: url("../../../warp/vendor/uikit/fonts/fontawesome-webfont.eot?#iefix") format("embedded-opentype"), url("../../../warp/vendor/uikit/fonts/fontawesome-webfont.woff") format("woff"), url("../../../warp/vendor/uikit/fonts/fontawesome-webfont.ttf") format("truetype");
font-weight: normal;
font-style: normal;
