[SOLVED] footer a
- moni
- Topic Author
- Visitor
I have got a problem with the design of the footer-a. I have two menues in the footer-a:
Impressum and Kontakt.
www.tschenett.info/ERSTE_HILFE/
Please see on the website. Impressum is in grey and contact is black. I have no idea how I made the grey bar of the impressum.
I want to visual the contact bar the same way.
by moni
The grey bar is an active link and I dont know why!
Please create another menu item and clean the Joomla cache and the menu cache from module.
Attachment aktiv.jpg not found
- moni
- Topic Author
- Visitor
Ok - done, now the Link is black as the other...
But how can I change the Background of the Link? - You have to click on the Link to make the link-text visible.....
by moni
- moni
- Topic Author
- Visitor
www.tschenett.info/TECHNIK/index.php/home
How can I leave the Titel of the site (Home - in this case)?? Not with "Show titel" yes or no..... because this istn't the Titel of the document.
by moni
Link Color:
Add this code to your file: css / custom.css
The "home" is the title and can be disabled at the menu item > options
.uk-nav.uk-nav-parent-icon.uk-nav-side a {
color: #fff;
The following user(s) said Thank You: moni
- moni
- Topic Author
- Visitor
Attachment Home.png not found
I have tried many adjustments of "Titel" on or off....
Please describe detailed - which menue, etc.
Thank you
by moni
