[SOLVED] Reduce space between modules
  • Actors
Reduce space between modules was created by Actors
Posted 10 years 1 month ago #7141
Its posible reduce space between modules? In your demo is diferent to my web....
Thanks...
by Actors
Replied by joomlaplates on topic Reduce space between modules
Posted 10 years 1 month ago #7145
and where can I see your site? Live Url please.
You can reduce the gap ( margin/padding) at the Customizer > Advanced > Grid margin horizontal/vertical
Video, how to use the customizer
www.joomlaplates.com/support/documentati...the-customizer-warp7
  • Actors
Replied by Actors on topic Reduce space between modules
Posted 10 years 1 month ago #7157
You can be a little more specific? I've tried everything there, in set warp but could not find where padding modify the content of the module with the edge of the module.
THanks.
by Actors
Posted 10 years 1 month ago #7158
Give me more details and live url with screenshot which gap do you mean!
After that I can be more detailed.
  • Actors
Posted 10 years 1 month ago #7160
Thank for your answer...
by Actors
Posted 10 years 1 month ago #7164
Ok, now I know what do you mean!
If you dont want any gap for the module, please setup the module parameter to "blank".
See image attached.
Attachment BLANK.jpg not found
The following user(s) said Thank You: Actors
