Login Module not shown on iPad etc.
- ryanheld
- Topic Author
- Visitor
I have a Login Module placed on the menu position. It shows up on normal browsers but when I switch to e.g. an iPad the module is not visible in the responsive scrolling menu.... Any ideas how to make it visible there?
Many thanks,
Ryan
Many thanks,
Ryan
by ryanheld
Replied by joomlaplates on topic Login Module not shown on iPad etc.
Posted 9 years 11 months ago #7893
You have to duplicate the login module and publish the module on module position > offcanvas
- ryanheld
- Topic Author
- Visitor
Hi
thanks for the quick reply -
as there is no predefined module position "offcanvas" in this template I have to define this position first, right?
Thanks, best
Ryan
Thanks, best
Ryan
by ryanheld
Posted 9 years 11 months ago #7898
Sorry my fail, the X2 has no offcanvas position.
Therefore its not possible to publish the login on mobile menu.
You have to publish the login module on any other module position and add the module class suffix: hidden-desktop
- ryanheld
- Topic Author
- Visitor
Thanks for the reply -
I've just tried this out but it's not working: there is no login module showing up on the ipad.
Any idea?
Thanks, Ryan
Any idea?
Thanks, Ryan
by ryanheld
Posted 9 years 11 months ago #7908
Publish the login module on module position "top-a" with a module class suffix: hidden-desktop
