[SOLVED] Slider Sizing Problem
- coreyang
- Topic Author
Hi there.
Appreciate help with slider issue.
Trying to get slider to occupy entire page as in your demo, but can't seem to do so.
Mine occupies about 3/4th of the height of the page (see attached screen shot)
What size image should I use?
Height and Width settings for widgekit slideshow to be set as auto?
Many thanks.
Many thanks.
by coreyang
- Thank you received: 1740
Hi there, the org. image has asize of: 1400 x 795.
You can change the header height from Joomla template options, because the image is the site background and would be scaled proportional to the Browser width and height.
- coreyang
- Topic Author
Great thanks. Have got the slider of the correct size.
However, the "overlay" ie. the white page which overlays the slider is too high up, blocking too much of the slider.
How do I go about shifting it down?
Thank you.
Thank you.
by coreyang
you can change the height of the slider at the Template options:
Attachment slider-height.jpg not found
- coreyang
- Topic Author
I tried doing that, but it changes the size of the slider and not the position of the overlay page.
by coreyang
The overlay depends on your margin-top and margin-bottom. ( space from top & space from bottom.
If you insert a logo like this:
you get a space of 200px from top and from bottom<div style:margin:200px 0>any content</div>
