[SOLVED] Snowflake Template questions.
  • keithshampine
  • Topic Author
  • Visitor
  • Visitor
Snowflake Template questions. was created by keithshampine
Posted 9 years 9 months ago #8710
I am brand new to JoomlaPlates and have a couple questions.
Yesterday I updated to Joomla 3.4.2.
Question 1: A small issue I'm having since updating to 3.4.2 (not sure if there is a correlation here or not) when I open the template settings and click Save and Close it will not close the page. The body of the page simply goes blank but does not close. In order to make a change, I click Save. The body goes blank, then I click Close and it will close. So essentially I can still make changes, but for some reason the Save and Close button is not working properly.
Question 2: Certain modules (site logo, main menu and custom HTML in the Search position) does not show on mobile phone. These modules are not listed in the Modules in template settings (options), but the module for Custom HTML in the footer position and RokSprocket Mosiac module in the top-a DO show up in the Modules in template settings.
Regards,
Keith
by keithshampine
Replied by joomlaplates on topic Snowflake Template questions.
Posted 9 years 9 months ago #8712
Hi Keith,
please make sure that you are using the latest Warp version:
  • keithshampine
  • Topic Author
  • Visitor
  • Visitor
Replied by keithshampine on topic [SOLVED] Snowflake Template questions.
Posted 9 years 9 months ago #8713
by keithshampine
Replied by joomlaplates on topic [SOLVED] Snowflake Template questions.
Posted 9 years 9 months ago #8714
Hello Keith, how did you solved the problem? Did you updated the Warp framework to 7.3.7?
  • keithshampine
  • Topic Author
  • Visitor
  • Visitor
Posted 9 years 9 months ago #8717
First, the extension manager would not let me install the zip package of the warp 7.3.7 so I installed it via FTP without problem.
From the link you pointed me to, I was able to learn how to show the logo on phones via the logo-small position, which I was not aware of. As well as the mobile menu via the offcanvas position.
The Save and Close button in the template setting still is not working properly however this is not a problem as I can click Save, then Close button which ultimately accomplishes the same goal, just with one extra step.
I assume now only certain modules show up in the Module Options area in the template settings?
A appreciate the support you are offering; it helps a great deal
Regards,
Keith
by keithshampine
Posted 9 years 9 months ago #8720
Hi Keith,
we have now updated the ZIP files on our server and you should do the update once again to the version: 7.3.7
## Changelog
7.3.7
# Fixed missing closing <a> tag in article override (J)
# Fixed saving template settings failed (J 3.4.2)
# Fixed 'max_input_vars' error on save/close template settings (J)
# Fixed article links override (J)
# Fixed empty config saving
7.3.6
^ Updated UIkit to 2.21.0
# Fixed returnURL of hidden articles after user login
# Fixed MooTools hide issue
And the module options are only availabe for some modules like: top-a, top-b and so on..
If you want to show the search module or toolbar modules you have to delete the syntax: uk-hidden-small from the file:
layouts/theme.php
Attachment uk-hidden.jpg not found
Last Edit:9 years 9 months ago by joomlaplates
Last edit: 9 years 9 months ago by joomlaplates.
