Menu on mobile devices
- HelpendeHonden
- Topic Author
- Visitor
Hi!
I really like the Galeria template, and I find it really easy to adjust to my needs.
One thing I like less though, is the main menu on mobile devices. I am used to the four little lines in the upper corner signaling the menu (like the template of this forum...), but the Galeria template displays a rather unpleasant and seemingly un-styled drill-down-box. Other Joomlaplates templates have the four-lines-menu style in mobile devices, I notice.
How can I get this working on the Galeria template?
by HelpendeHonden
Hi there, the Gallery theme is based on Warp6 and has this mobile menu which is included.
The other themes like this one is based on Warp 7 and have an "offcanvas" menu with 3 lines.
And its not possible to add the offcanvas menu into the Gallery theme.
- HelpendeHonden
- Topic Author
- Visitor
Thanks for your swift reply.
Is there a way to style the mobile menu somehow, through css maybe?
by HelpendeHonden
- HelpendeHonden
- Topic Author
- Visitor
On second thought, since I am just starting this new website: should I invest in Warp6 or should I start over with a Warp7 template? In that regard: does the Blog template support having the mainmenu in a sidebar, with sublines like in the Galeria template?
by HelpendeHonden
Yes the "blog" theme is based on Waarp7 and have this offcanvas menu you like.
- HelpendeHonden
- Topic Author
- Visitor
And about mainmenu in sidebar module position?
by HelpendeHonden
