mobile responsive view
- magach
- Topic Author
ok but that problem is still present : iff canvas menu too high on my index letting a blank space
how can i fix that ?
by magach
And you still have a html site problem.
I dont where the script code comes from, but the red part is wrong
Attachment script-error.jpg not found
- magach
- Topic Author
I'm an ass but where is the file that i should modify located ? i don't find it ..
by magach
Youre not an .....ss
I told you that have to check all your installed extesnions.
Disable all extensions and then enable each extension and check the site.
- magach
- Topic Author
I'm losing my mind dealing with that I came p to change the code but desactivate all plugins didn't change anythink i'm stucked what can I do
www.ecni-network.fr
www.ecni-network.fr
by magach
I will take a look, please provide me admin access via mail to:
support@joomlaplates.com
