mobile responsive view
- magach
- Topic Author
- Visitor
I'm a newbie on that kind of stuff but i purchased and made up a nice website using your theme SnowFlake . The fact is that i want to adapt it for smartphone using your responsible warp framework.
But first, the mobile menu at offcanvas position appears too high and a the wrong position when connecting from the phone.
And secondly I have also installed Jomsocial but how can i adapt the mobile viw to all that stuff ( modules / plugin ..)
And if it's too hard, is it possible to desactivate for a while the mobile version until i get one that works.
thanks in advance for your help!
by magach
First at all, live url please.
The mobile version can not be disabled. And Joomsocial must be responsive and if not its a extension problem and not a template related.
- magach
- Topic Author
- Visitor
thks for your fast answer. What can it be if it's not a template problem ? you can see by yourself connecting to
www.ecni-network.fr
thx
thx
by magach
Hi there, you have a script/html error on your site, see image below
Maybe it depends on your installed extension (joomsocial or ckk), but I dont know!
1.) Install the theme and check everything.
2.) Install extension and check it again
3.) Install the other extension and check the site again
and so on...
We cannot guarantee the templates will function with all 3rd party components as there is currently no certification process for such components.
and so on...
Attachment error_2015-08-29.jpg not found
Last Edit:9 years 7 months ago
Last edit: 9 years 7 months ago by joomlaplates.
- magach
- Topic Author
- Visitor
Thx and u think that this error due to a plugin fb share button is enough to explain all of this ?
thx a lot for your time
by magach
Sorry I dont know!
Disable all plugins and then check the site.
After that you can try to enable each plugin and check the site again..
