[SOLVED] Remove content article on front page only
Remove content article on front page only was created by tchmichael
Posted 9 years 7 months ago #9521
How do you remove the front page content article page? So when the site loads up it will only show modules like a dashboard ?
Replied by tchmichael on topic Remove content article on front page only
Posted 9 years 7 months ago #9567
The only thing I can think of is install the template 2 times. Modify 1 of the template to only show the front page - which will have a modified edited version without the content space. The rest of the template can use the original for all the other existing pages.
Does anyone have any other suggestions ?
Replied by joomlaplates on topic Remove content article on front page only
Posted 9 years 7 months ago #9573
No no thats not possible.
Please follow these steps to disable the system output for menu items
1.) Template Options > Layouts > Add a new Style
2.) Select this Style now
3.) Select "Hide System Output"
4.) Scroll down and select the menu item
Attachment system-output.jpg not found
Last Edit:9 years 7 months ago by joomlaplates
Last edit: 9 years 7 months ago by joomlaplates.
Posted 9 years 7 months ago #9589
Thanks. This works, except now I'm left with a huge blank white space where the content was supposed to go. Is there a way to hide the display only for the main homepage ?
Posted 9 years 7 months ago #9652
Is there a way I can enable a separate stylesheet for just that home page ? with a display:none; to css for that content space ?
Posted 9 years 7 months ago #9657
If the home menu item has the system output disabled:
Please make sure, that the following modules are not assigned to your menu item "home"
- sidebar-a
- sidebar-b
- main-top
- main-bottom
- breadcrumbs
The following user(s) said Thank You: tchmichael
