Change "read more" to "lire la suite..."
Replied by joomlaplates on topic Change "read more" to "lire la suite..."
Posted 10 years 5 months ago #10448
You can disable the module on position "footer" to disable the Joomly copyright
Last Edit:10 years 5 months ago by joomlaplates
Last edit: 10 years 5 months ago by joomlaplates.
  • philvig
  • Topic Author
Replied by philvig on topic Change "read more" to "lire la suite..."
Posted 10 years 5 months ago #10449
Yes, i see... But i disable all the copyright... : (
by philvig
Posted 10 years 5 months ago #10450
Yes and then create your own copyright with a custom module.
www.joomlaplates.com/support/documentati...the-copyright-footer
  • philvig
  • Topic Author
Posted 10 years 5 months ago #10451
Yes.... I see... Green = deleted ?
by philvig
Posted 10 years 5 months ago #10454
Green = published
Red = unpublished
Joomla Guide
cocoate.com/sites/cocoate.com/files/private/j3en.pdf
The following user(s) said Thank You: philvig
  • philvig
  • Topic Author
Posted 10 years 5 months ago #10455
: ) Pdf... Merci.
I see colors white, bleu and green with this link : www.joomlaplates.com/support/documentati...the-copyright-footer
Sorry, no red... I think the solution = unpublished green ?
by philvig
