Change "read more" to "lire la suite..."
- philvig
- Topic Author
- Visitor
I'm a new french joomla user and i use the template Life...
Could you help me please to traduce "read more" fot "COOL STRIPS LAYOUT"...
I want change with "Lire la suite..."
I read a lot of forum with differents solutions, but no result...
Thank you.
Thank you.
Last Edit:9 years 5 months ago
by philvig
Last edit: 9 years 5 months ago by philvig.
Replied by joomlaplates on topic Change "read more" to "lire la suite..."
Posted 9 years 5 months ago #10443
you can setup your own language translation at Joomla language override function.
>> Extensions > Language > Overrides > New
And now insert your override in this case it is "READ_MORE" and insert your own language text below
Attachment language-001.jpg not found
Attachment language-002.jpg not found
Last edit: 9 years 5 months ago by joomlaplates.
- philvig
- Topic Author
- Visitor
Replied by philvig on topic Change "read more" to "lire la suite..."
Posted 9 years 5 months ago #10444
Thank you,
Yes, i do this ... With a lot of new override create when i find "read more"... I change text : "lire la suite..."
But, it's always the same : no difference online, "read more" appear...
I don't know why....
by philvig
Posted 9 years 5 months ago #10445
You should take the right language. If youre using "french" language as default you have to assign this override to french languege too.
If nothing works you have to change the language file directly at
Joomla \components\com_roksprocket\language\en-GB\en-GB.com_roksprocket.ini
- philvig
- Topic Author
- Visitor
Posted 9 years 5 months ago #10446
Hey... I just see that if i choose "english langage" for site, i have the traduce : "lire la suite"....
So, i need woork with english langage defaut for site ?
Thk.
Thk.
by philvig
- philvig
- Topic Author
- Visitor
Posted 9 years 5 months ago #10447
Thank you very much : )
I close this discussion with solved. But...
Before, perhaps could you say me the solution with footer : just copyright society but no see "joomla is free software released under the GNU General Public License.....
by philvig
