[SOLVED] Dropdown Animation Settings on Main Menu
  • cct
Dropdown Animation Settings on Main Menu was created by cct
Posted 9 years 2 weeks ago #13352
Hi
The drop down menu on the demo site has a nice animation but my installed site doesn't have this effect. How do get thsi this effect and how do I adjust it the timings. I like the demo although a little bit faster to drop down on the hover would be good, and a little bit faster at disappearing when pointer is moved away.
Also, the sticky main menu disappears then reappears after scrolling so far, how do I adjust the amount of scroll before it re-appears.
Thanks
CC
by cct
Replied by joomlaplates on topic Dropdown Animation Settings on Main Menu
Posted 9 years 2 weeks ago #13353
Live url please.
And the dropdown animation can be changed at Template customizer > Advanced > dropdown > animation
  • cct
Replied by cct on topic Dropdown Animation Settings on Main Menu
Posted 9 years 2 weeks ago #13374
Sorry I don't have a Live URL only IP Url, I can Private message you if this is possible, or email?
I tried the dropdown animation but doesn't seem to make any difference what i choose from the 3 options. I tried animation and nav bar animation both in the customizer
by cct
Posted 9 years 2 weeks ago #13375
You can add this code to your css/custom.css to override the animation:
* 1. Show dropdown
* 2. Set animation
* 3. Needed for scale animation
.uk-open > .uk-dropdown,
.uk-open > .uk-dropdown-blank {
/* 1 */
display: block;
/* 2 */
-webkit-animation: uk-fade 0.2s ease-in-out;
/* 3 */
-webkit-transform-origin: 0 0;
.uk-open > .uk-dropdown-navbar {
All animations can be found here:
getuikit.com/docs/animation.html
Last Edit:9 years 2 weeks ago by joomlaplates
Last edit: 9 years 2 weeks ago by joomlaplates.
The following user(s) said Thank You: cct
  • cct
Posted 9 years 2 weeks ago #13376
I tried this css before but no success, this time it works good. Thank you.
It does seem a little slow at closing the dropdown but I think I read in the forum this can't be fixed, it's a browser problem?? Can this be changed to be quicker to close dropdown yet?
by cct
Posted 9 years 2 weeks ago #13377
You can try only "ease-in" instead of "ease-in-out"
