Problem with widgetkit gallery
Hello.
I am using widgetkit extension.
I tried a module with mosaic gallery with a fullpage lightbox effect (please see/try it at www.theblackstuff.it/main , in the middle of the page, module titled "menu")
With sticky menu on, this module doesn't work properly with chrome (in firefox all is ok). I already asked to widgetkit people to help me, but they say it's template problem.
The main error is that I can see the "X"at top right corner for closing lightbox, because this box goes under sticky menu instead of over.
It seems like a z-index problem but my knowledg is to limited to solve it. Please could you help me?
Thank you so much.
Thank you so much.
Last Edit:8 years 6 months ago
by amaida
Last edit: 8 years 6 months ago by amaida.
which lightbox do you mean exactly, we need a screenshot or anything else.
And please take in your mind we do not support the "widgetkit 2" because its not working together with roksprocket modules.
Maybe here is the problem!
Yes I'm using widgetkit2.
It's sad because I have only a problem with this gallery and only with chrome. If you can consider my problem anyway, here is a screenshot of how it doesn't work with chrome the gallery:
www.theblackstuff.it/Cattura.PNG
(I can't see the X to close on top right plus plus, if I try to use smooth controls on the right, the content will it showd over the gallery...)
Thanks, regards.
Thanks, regards.
by amaida
Live url where I can see the popup!
The Gallery popup is working well!
The following user(s) said Thank You: amaida
. Here is the live url. With chrome doesn't work properly...
by amaida
I cant see any issue with chrome, see image attached.
Maybe you can hide the absolute menu, therefore add this code to your css/custom.css
.absolute {
z-index: 0;
Attachment chrome-2.jpg not found
Last edit: 8 years 6 months ago by joomlaplates.
