[SOLVED] Mosaic
Before I changed over to the 'Bike' template I had a go using the 'B&W' template. I then decided I preferred the full screen type of page so went for the Bike template. however I still wanted to use the mosaic module in the bike theme on my page somewhere. I have set this up, but it doesn't look the same as the mosaic on the 'b&w' theme homepage. For example ;
1. on the B&W mosaic if you put mouse over a picture it will zoom in and then you can click and it will open a box with the photo - is there a way to turn tis option on or is this only an ooption on the B&W theme?
2. on the 'B&W' mosiacs they look like Polaroids, with a white border and sharp edges. When I have used the same layout style in the bike theme it is a smaller boarder around the photo, its grey not white.
I've looked at the rokspocket website and they show the mosaic as I decribed they are in the bike theme, but wonder how I can get it to look like they do int he 'B&W' themes home page?
Thanks
Thanks
by retaildco
the Bike theme have no style override for the mosaic option, because we have not include the mosaic in bike theme.
You have to copy the override (roksprocket folder) and the css codes from B&W theme to the Bike theme.
i have jp-sound and works great with mosaic
now i have the same problem with jp-bike like above...
i configurate the answare from jp and its works... only one thing is not correct... if you click on the picture it gos not open in a box. the link goes to a new site, and overite the jp-bike site... then you have to go back with the back button. where can i fix that problem?
neu.carkos.ch/index.php/angebot/beschriftung
this is the problem site...
hp-design.ch/index.php/angebot/fotografie/fotoshoot-natur
this site is working correct
thanks for help and sory for my bad english
by chiefhenk
the bike theme has no lightbox included.
Please add the "lightbox" code to your file: \templates\jp-bike\layouts\theme.config.php
in line > 126. See image attached$this->addFile('js', 'warp:vendor/uikit/js/components/lightbox.js');
Attachment lightbox-2.jpg not found
