[SOLVED] Header in the middle and between lines
  • Projekt Partner
  • Topic Author
Replied by Projekt Partner on topic Header in the middle and between lines
Posted 9 years 8 months ago #14734
I did all that, what you said:
result:
by Projekt Partner
  • Projekt Partner
  • Topic Author
Posted 9 years 8 months ago #14735
The pictures are not going through.
by Projekt Partner
  • Projekt Partner
  • Topic Author
Posted 9 years 8 months ago #14736
I put in HTML of the article page the code.
I turned "Show Title" in the options of the Article on Hide.
Result... not what I wanted. Sorry.
by Projekt Partner
Replied by joomlaplates on topic Header in the middle and between lines
Posted 9 years 8 months ago #14737
Hi again,
sorry I could not see the class and the headline in your site, see image below
Attachment error-2.png not found
1.) Goto system config and disable the tiny editor
2.) Now insert this code below for your headline
<h3 class="uk-panel-title">Die Gemeinde</h3>
  • Projekt Partner
  • Topic Author
Posted 9 years 8 months ago #14739
Attachment status.jpg not found
it is "Bürgerinfo/statistische Daten"
thats what I did.
I have the JCE editor.
Maybe I changed, while trying, something else... but what?
Thanks.
Last Edit:9 years 8 months ago by Projekt Partner
Last edit: 9 years 8 months ago by Projekt Partner.
Posted 9 years 8 months ago #14743
As I told you above, please disable the "stupid" Editors and insert the code direct in html modus without any editor
