[SOLVED] Header in the middle and between lines
  • Projekt Partner
  • Projekt Partner's Avatar Topic Author
  • Visitor
  • Visitor
Header in the middle and between lines was created by Projekt Partner
Posted 8 years 4 months ago #14616
Attachment text_linie_mittig.jpg not found
I know there was a post already. but I did not get it.
does that only work, if you show the titel of the page?
I would like to have h3 so formatted. Is that possible?
Or how should I do it.
Thanks!
by Projekt Partner
Replied by joomlaplates on topic Header in the middle and between lines
Posted 8 years 4 months ago #14619
Add this html code to your article or module and it should works
<h3 class="uk-panel-title">Enjoy Our Gourmet Dinner</h3>
The following user(s) said Thank You: Projekt Partner
  • Projekt Partner
  • Visitor
  • Visitor
Replied by Projekt Partner on topic Header in the middle and between lines
Posted 8 years 4 months ago #14621
I did. In the HTML code of the article. Nothing changed.
by Projekt Partner
Posted 8 years 4 months ago #14626
Live Url please
  • Projekt Partner
  • Visitor
  • Visitor
Posted 8 years 4 months ago #14716
URL landing page: landing page
on all pages , like this one : page
"Die Gemeinde" should be like "Take a look at our design"
by Projekt Partner
Posted 8 years 4 months ago #14718
As i told you above, please insert your title with this code into your Joomla article.
After that you have to disable the org. Joomla artile title
<h3 class="uk-panel-title">Die Gemeinde</h3>
Attachment h3-2.jpg not found
