[SOLVED] Logo not showing on mobile
Logo not showing on mobile was created by joepke-m
Posted 8 years 3 months ago #14921
I am using the X2 template on www.footcare-4-you.nl/nieuw but the logo is not showing when using a mobile phone or tablet. Is it possible to show the logo responsive
Replied by joepke-m on topic Logo not showing on mobile
Posted 8 years 3 months ago #14942
Tried to solve it somehow but failed. Please advice
Replied by joomlaplates on topic Logo not showing on mobile
Posted 8 years 3 months ago #14950
please put your logo into the logo position and it should works
Attachment logo-2-3-4-5.jpg not found
Posted 8 years 3 months ago #14951
I am not sure what you mean. I followed the instructions in the documentation and therefore added a Custom HTML module in position "logo". The logo shows on a large screen, but not on mobile or tablet.
<p><img src="images/Footcare4you_RGB.jpg" alt="Footcare4you" id="logo" style="margin-bottom: 10px; float: right;" /></p>
<p><img src="images/lijn.jpg" alt="lijn" style="margin-bottom: 10px; float: right;" /></p>
Last Edit:8 years 3 months ago by joepke-m
Last edit: 8 years 3 months ago by joepke-m.
Posted 8 years 3 months ago #14953
please disable the Joomla editor and use only the HTML Code or Editor = NONE
Now add this code:
<img src="images/Footcare4you_RGB.jpg" alt="Footcare4you" style="margin-bottom: 10px; float: right;" />
The following user(s) said Thank You: joepke-m
Posted 8 years 3 months ago #14954
Thanks! Almost there...
The logo is showing on mobile view, but unfortunately the menu bar is only half visible now.
Is there anything I can change to give it a little more space?
