Change Color for Links dont work
Hello
My Homepage had a Menu for change Color (for the visitors).
Look at the Page on the menu "Deine Farbe" on Website knipsografen.ch.tiberius.sui-inter.net/
All Color-Change-Items work perfectly.
But the "Gelb"-Changer had Problems. I only wont change the background on the Menu and the link-color.
Look at the Attachment.
Correct:
Incorrect:
I had make a copy of the default Color in the Customizer an set the "Link Color and Primary Background.
Thank you for your help.
Correct:
Incorrect:
by Nilsen
Replied by joomlaplates on topic Change Color for Links dont work
Posted 8 years 2 months ago #15051
please duplicate your wanted style within customizer.
After that you can change what you need.
To change the orange color, please select all "orange" color fields to your won one.
See image attached.
See image attached.
Attachment customizer-2-3-4-5.jpg not found
Hello
Thanks for your qiuck answer. But you read my text not so good
I had make a copy of the default Style and chanche the value.
I can change the Menu-background color without problems.
But the link-color dont change - they had the same color like the default styxle.
All other styles that i change - word perfrectly
Pleas look at the Attachment
Thank you very much.
by Nilsen
Posted 8 years 2 months ago #15072
if you could not find the link color in customizer, add the css code manually into the css/custom.css
a, .uk-link {
color: #de6e02;
Thank you for the Answer.
When I set the link color on the CSS File - all links change to the neue color (yellow).
But i want only change the link color of the style yellow (/?style=yellow)
The visitor should have the choise of 5 color-sets with different colors of links, menu-background and other buttons.
Do you have a CSS-Code to change only the link color of the Style /?style=yellow
by Nilsen
Posted 8 years 2 months ago #15077
You can add the "custom.css" to your folder:
>> styles/yellow/css/custom.css
too
too
The following user(s) said Thank You: Nilsen
